max bore for a banshee
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Jun 2006
    new jersey
    33
    Default max bore for a banshee
    i have a banshee with idk what bore in it rite now but he said it comes out to be 410cc with a 4mm stroker. i have stock carbs with open pro design airbox adapter with 360 mains in them and cool head with 20cc domes and v force 3s i was wondering what the max bore i could go to in the winseco line like .80 1.00 .20 etc. and is it safe and how does it work on stock ported cylinders ??? please reply i ride recreational so something that will give the most power and displacement thanx
    Oct 2006
    Pennsylvania
    17
    mine is bored to .08 over, which puts it at 66mm. For the wiseco stroker kit, long rod,that is the biggest piston they make. that kikt has 4mm on the crank and 3 mm longer rods. i think the 310 main is too big, do u foul plugs, mine is jetted at 240 with stock carbs and i can let it idle all day if i want. The guy that set my carbs up told me that its a common mistake to overjet because everyone thinks more gas more power, but thats not always the case i suppose.
    Oct 2004
    pennsylvania
    14,217
    Exclamation
    Quote Originally Posted by bansheeRev404
    well if you have a h129 wiseco stroker crank youd need 795 series wiseco big bore pistons ( big bore stroker domes would effect piston choice too) for that setup and it wil lbe much bigger than traditional stock sleeve style bore pistons .theres some very important missing info as to your setup and youll need to know the bore size for anybody to be if help.i highly doubt yo u have the correct info listed ...as a 410cc number on a 4millimeter cran k would require yo u to have a 67mm bore which is an oddball size .big bore sleeves generally start at 68mm and up this yeilds 421cc of displacement .youll need to tear your eninge to know .
    CLICK BELOW FOR MY NEW SITE
    http://www.rjatv.com/
    Jun 2006
    new jersey
    33
    ya i got a 4mm stoker all ready and ya the guy did alot alot of engine work on my bike so thats why i have the 360s in plus its gettin cold in new jersey rite now so i need gas and believe or not its still runin a bit leannnn so how much power did u see from the pistons
    Oct 2004
    pennsylvania
    14,217
    Question
    im confused yo u have stock sleeves in your bike now? and your going to add this 4mill stroker crank ? you were told it would be 410cc? It is already ported ? what bore is it now ? you wont have 410cc with stock sleeves ,
    Oct 2006
    Pennsylvania
    17
    Quote Originally Posted by eviltwin
    u don't need sleeves up until over 2mm oversize. there is no stock "sleeve" its just a cylinder like any other cylinder
  9. #7
    Oct 2004
    pennsylvania
    14,217
    Quote Originally Posted by StrokinBanshee
    okay sorry guy lol let me see if i get this right ...the " factory cylinders" ,and you can actually go .100 over on them bTW , but it is a very bad idea.
  10. #8
    Oct 2004
    pennsylvania
    14,217
    you have a piped 4mill with 240 mains? ,geez thats scary lean. the rods are not 3mm longer, they are 115mm long making them 5 millimeters longer than stock .
  11. #9
    Jan 2006
    Nevada
    1,230
    i would listen to eviltwin(denny)....hes done this for a while and he definatley no's what hes talking about......most of the time..lol j/k
    2005 YZ250 - FMF Gold Series Fatty Pipe, Titanium 2 Silencer, UNI Filter
    2006 YZ450F - White Bros Full Carbon Exhuast, UNI FIlter
    92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
  12. #10
    Jan 2012
    northwest indiana
    0
    stock cylinders on a banshee are SLEEVED... an onsleeved cylinder would be cast alum with a nikisil coating which... banshee DO NOT have... and a H129 wiseco crank with stock SLEEVES cannot get you a 410cc.... mine is a 65mm bore and a 4mm stroker long rod..... and i beleive mine figured out to a 385 or somewhere right near that....
    STOCK CARBS???? why??
