Hot Rods Crank..Stroker or Not?
Results 1 to 10 of 10
    Feb 2007
    Illinois
    259
    Default Hot Rods Crank..Stroker or Not?
    i have an old blaster i am parting out and i looked at the bottom end and noticed it had a hot rods cranks in it. so i am wondering if it is a stroker or not. it say C.K. 144 on the rod and also says hotrods on the rod. The actual crankshaft has H.R. and a symbol on it. Thanks.
    #212 2009 Polaris Outlaw 525 IRS
    Pro Armor/FMF/AC Racing/CV4/UNI
    1987 LT250R XC/woods racing/harescrambles setup SOLD :(
    2002 Yamaha Blaster SOLD :(
    Nov 2007
    Ct
    99
    well i kno i have a stroker in mine, and it says the same thing on the rod, but i have never actually seen the crank, out of the case.
    Dec 2006
    South Fork,Pa
    2,813
    You can't tell without measuring it. If the crank is out, measure the distance from the center of the crank to the end of the rod at tdc then measure the distance at bdc. tdc - bdc = stroke.
    Never argue with an idiot. They'll just drag you down to their level and beat you with experience
    Feb 2007
    Illinois
    259
    is there a way to check if it is still in the bottom end??
    thanks
    Dec 2006
    South Fork,Pa
    2,813
    Take a metric ruler and measure from the top of the case tdc and bdc. Same thing just make sure you measure from the exact same spot on the case. You dont have much room for error doing it this way, 3mm is not that much of a difference
    Feb 2007
    Illinois
    259
    yeah that is kind of what i was thinking...i will have to be very accurate to be able to tell 4mm of a difference. i contacted hot rods and their engineer wont be back unitl friday, so i figured i would ask on here. stock stroke for a blaster is 57mm, right? and how do you get it exactly at tdc and bdc? thanks
  9. #7
    Feb 2007
    Illinois
    259
    someone tell me if this will work--put the clyinder and piston on and then measure from the top of the cylinder to the top of the piston at tdc and bdc--it jsut seems that it would be more accurate to do it that way. thanks
  10. #8
    Feb 2007
    Illinois
    259
    well i measured it both ways and i got 57mm...so i guess it is a stock stroke..thanks for the help guys
  11. #9
    ya but i still would check with the engineer at hot rods to make sure
  12. #10
    Nov 2007
    Ct
    99
    when you check, you mind posting it, id like to know. Thanks
