How to build a 2-stroke muffler the right way ??
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Question How to build a 2-stroke muffler the right way ??
    :confused6 :confused6 :confused6
    Hello !
    What should I think about when I building my own muffler/silencer for a 2 stroke engine ?
    Some guidelines ?
    How to ?
    Do and dont's ?
    Engine : Rotax 793 HO
    Max Rpm : 8000 rpm
    Number of cylinders : 2
    Max output : 140 Hp
    Carb : 2 * Mikuni TM-40
    Lasse from SWEDEN.
    Oct 2004
    pennsylvania
    14,217
    rule number one on silencer building ,-dont do it
    rule number two -buy one instead
    CLICK BELOW FOR MY NEW SITE
    http://www.rjatv.com/
    Jan 2007
    Campbell Missouri
    1,475
    yeah just buy one.. even if you go buy a stock one used... don't mess with trying to make one
    Rebirth of the blaster??
    Talking
    Who said life is easy ? *LoL*
    serious....
    I want to build my own muffler/silencer because there is no one out there for my aplication.....
    Someone have some advice ?
    Lasse from SWEDEN.
    Jun 2007
    Pismo Beach, Ca
    8,558
    Jul 2004
    Big Rapids, Michigan
    2,332
    I visited Sweden just over a year ago. Beautiful country, & Beautiful vehicles.
    As for the silencer, I also have to admit that buying one is the most beneficial choice. However if you have a fabrication shop, they could be made. Does it have to be Spark Arrested?
    1985 LT250R Quadracer
    Manufacture Date: 12-84
    Hot Rod +8mm Rod, Cometic Alum. Spacer
    FloTek Drag/Dune port w/ Head Mod
    LA Sleeve STD Bore
    Weisco Piston
    AAEN Pipe
    FMF Turbine Core II Universal
    1Dirracing Ported Reed Block w/ Secrets
    Keihin 39mm PWK
    Nology Pro Fire Coil & HotWires
    7oz off FlyWheel
    Barnette Kevilar Clutch Kit
    K&N Cone Filter
    Burgard+2 +1 Chrome A-Arms
    +4 Chromoly Swingarm
    WORKS Fronts w/ Rezzys
    DuraBlue Rear Strut
    SRP Billet Twin Row Carrier
    LSR Axcaliber +2 Axle & LSR Brake Hub
  9. #7
    Jul 2007
    california
    227
    that and your going to have to special order the muffler bearings. You could try and build them yourself but its alot of work
    "Second place is nothing more than the first loser"
  10. #8
    Arrow
    Quote Originally Posted by lt250racer
    Does it have to be Spark Arrested ?
    Nice that You liked our country !
    Welcome back !
    No, it not need to be spark arrested !
    Lasse from SWEDEN.
  11. #9
    Question
    Quote Originally Posted by SkinStroker
    I do not know the word muffler bearings ?
    Lasse from SWEDEN.
  12. #10
    Jul 2004
    2,332
    He was implying a joke. All you need is a outer case with a tube traveling though it, but in the tube must have holes all thru it (see pictures). I would reccomend using Aluminum.
    The smaller tube with holes then gets wrapped in a fiberglass cloth.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	11154   Click image for larger version.
    LA Sleeve STD Bore
    Weisco Piston
    AAEN Pipe
    Keihin 39mm PWK
    7oz off FlyWheel
    K&N Cone Filter
    DuraBlue Rear Strut
