82 CR 125 swing arm bolt stuck
Results 1 to 8 of 8
    Feb 2008
    Ontario
    133
    Default 82 CR 125 swing arm bolt stuck
    I am restoring a 1982 CR 125 and I can't for the life of me get the long bolt out that goes through the frame/swingarm/cases. It goes about 1/2" then feels as if it's bottoming against something. Looking at it, I am guessing that the metal sleeve that the bolts rides through [and the sleeve sits inside the bearings in the swingarm] is rusted to the bolt, and moves far enough to contact the inner dust cover and stop against the engine case.
    I soaked it with penetrating oil, but wholly shit, my neighbor and I spent 2 hours tonight and nothing. This bike has been a large pain in the ass that's for sure. Fighting every step of the way.:violent3:
    Any ideas as to how to get this out, I have another 82 swing arm I am putting in because this one is busted, they used too long a bolt on the shock and it busted off a part of the arm [shock runs through the middle].
    -1981 RM 125 - I restored it mint, kid blew it up stuckin a snow bank w/ throttle pinned [he was trying to seize it]. Bike was like a new 81 RM125X. Now its blown up, and the asshat painted it purple. Seriously. So.. restoring it in spring, and likely keeping.
    -2002 XR 200R - New motor, bike is MINT. For sale.
    -2000 RM 125 - New Hot Rods bottom end, new top end [nikasil and all] bike is really nice shape, for sale.
    Mar 2007
    Vacaville, California
    6,471
    My Banshee did the same thing. I ended up using a sawzall and cut between the frame and swinger so the swingarm would fall out. Then I just bought a new bolt and sleeve.
    E2S MODERATOR
    1988 Yamaha Blaster
    Feb 2008
    Ontario
    133
    I spent a few more hours, and i'm at the limit of sanity. Tomorrow things involving cherry pickers and the bumpers of trucks hooked up to the bolt are going to be occurring.
    Funny I have never had even decent luck any Hondas I have owned, they have all been troublesome at best.
    This bike is going to lose......
    Feb 2008
    Ontario
    133
    Haha I WON... she's apart..
    Mar 2007
    6,471
    How did you end up getting it loose?
    E2S MODERATOR
    1988 Yamaha Blaster
    I just banged out the Banshee, not as bad as removing axle locknuts! But my bro's trx gave him gray hair for a few days!
    He attacked it good and got it out though!
    >> Get on E2S Member Map <<
    * 2001 350cc Yamaha Banshee * Wildcard Racing Duner Port Matched Cases* 64mm Bore *
    Wildcard Cool Head 19cc Domes * Wildcard Crank Rebuild *
    Wildcard Lightened Flywheel *
    UPP Intakes * 33mm PWK Carbs * UNI Air Filters * CPI Racing Pipes * Boss Racing Clutch Basket *
    Pro Lock Clutch * Shift Pro Kit * Flotek Shift Star * Fast Racing Shift Shaft * Pro Design Impellar *
    Quicksand Motorsports +2+1 A Arms * Works Racing Dual Rate Shocks * +4 Swingarm * +2 G Force Axle *
    Skat Trak 21x11x8x9 Hauler Paddles * 21x7x10 Mohawks & 21x7x10 GBC Dune Trackers * Trail Tech Headlights *
    IMS Kickup Pegs * IMS 4 Gal Tank * Wire Harness chopped by me *
  9. #7
    Feb 2008
    Ontario
    133
    A grinder. I cut down through the swing arm, and almost into the sleeve that was rusted to the bolt. Then my grinding disk, got too small, soooo, I got out my electric die grinder for doing heads, put a carbide porting bit in, and ported through the sleeve till I hit the swing arm bolt. At this point, I was able to pound it through.
    The swing arm was busted anyway so butchering it was an option thankfully. I got a lot done today on it.
    http://forums.everything2stroke.com/...tml#post325053
  10. #8
    Quote Originally Posted by YZSVO View Post
    And that's always a great feeling aint it?? I hate obstacles like this!!
