Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: banshee jetting
    Default banshee jetting
    I've got an 04 banshee with t-6's, v-force 2's, 1/2 inch reed spacers, toomey jet kit, toomey foam 2 into 1 filter, GYT-R cdi, boost bottle, and platinum NGK plugs. I'm using the recommended jetting from toomey- 280 main jets and needles on the 4th clip. Do I need to alter this any to go with anything other than the toomey pipes? Ex: reed spacers? I also live in Alabama and the humidity is a little bit higher than California where the pipes are made. It starts really easy, but I don't want lose any potential power I could be gaining from changing a little. What do you think?
  2. #2
    I noticed nobody has touched this one yet. Damn, I guess it's alright. I checked my plugs today and they look good. Dry, light brown, and no oil or buildup.
  3. #3
    Oct 2004
    pennsylvania
    14,120
    you should be very close with those jet sizes and mods IMO
    theres an old saying"if it aint broke dont fix it" :violent3:
    CLICK BELOW FOR MY NEW SITE
    http://www.rjatv.com/
  4. #4
    Feb 2004
    Milford NH
    8,580
    Blog Entries
    7
    I would say your off.
    The vforce and the airfilter will bump up the jet size. I would starting tuning and checking your plug
  5. #5
    Oct 2004
    pennsylvania
    14,120
    i noticed that vforce caused my bike to run richer than before even though it also increases air,but it increases fuel too and i thought the toomey needles were richer than the stock ones,but i would listen to banshee he has t6 pipes and knows his shit on jetting .its pretty hard to jet a bike over the net, but i would think if anything and its not right on than your just a tad lean on the main ,depending on elevation fuel/oil ratio and a host of other variables .try a 300 main just for shits and giggles and see if it revs out better on top and do a plug chop,id rather be giving a bike a little to much fuel than starving it and losing a bunch of power IMO
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  6. #6
    The tech at toomey told me that a lot of guys were running 270 mains with the t-6's in Florida, kind of similar weather and humidity. If I'm one jet size up at 280, wouldn't that be a little richer like you said. I don't know, it seems okay.
  7. #7
    Jul 2004
    Connecticut
    1,536
    Question
    Quote Originally Posted by eviltwin
    Where did you get that chart?
  8. #8
    What chart?
  9. #9
    Feb 2004
    Milford NH
    8,580
    Blog Entries
    7
    I was running 280's when I had only T6's but he has vforce and open air box which increases the air intake flow so you have to give your bike more fuel or atleast that was the case with my G3 setup I am running a 410 right now on 28mm mikuni's. I just had a boost jet installed by 1dirracing so now I have a 380 main and the boost kicks in after the 380 is at full from what I understand. not sure yet I haven't had time to play with it since I have been waiting on a gasket.
  10. #10
    Jan 2012
    northwest indiana
    0
    hey denny you have the benb jetgin FAQ link right??? give him that
