broken piston
Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: broken piston
    Jan 2008
    TEXAS
    1,434
    Default broken piston
    well i pulled the cylinder off for a lil work and i noticed this....wtf....what did this???? my pipe leaks a bit at the cylinder, could that have caused this? and where and y did a chunk come out of the side of the piston??
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	16154   Click image for larger version.
ID:	16155   Click image for larger version.
    LIFES FAST SOOOOOOO HAUL ASSSSSSSS
    s.i.mafia
    Apr 2005
    West/Central,PA
    5,567
    maaan!!! that frickin thing is nasty!!!
    i would def say something is out of wack with your bore or the ex. port..or something got in there and tore it up..are there any similiar wear marks on the other side of the ex. port?...why the chunk came out like that i couldnt say..maybe it just busted from the crack that runs into it..or something hit at the chunk and that cracked it the rest of the way.i would check the bore for roundness!
    i have several pipes leak..some worse than others and never had aproblem like that..i highly doubt a leaky pipe would do anything to that extent.
    http://www.nologycoils.com
    http://flotekperformance.com
    http://www.youtube.com/user/StrokedT...4?feature=mhum
    http://bbdrdirtdrags.com/
    PM for Best Deals on Nology Products
    Custom Fabrication Services: Drag-Bars, Steering Stems, Footpegs, Swingarms, Drag Struts etc.
    Also, Extended Steering Stems, Steel Swingarms & Custom Drag Chassis
    Longtravel Blaster Swingarms
    Quality 4130 Chromoly Material
    *Custom Powdercoating*
    PM for a quote
    Mabey this is the cause why you said you lost or didn't have full power at the dunes dude.
    What the hells the rust from man, you were running that shit like that YIKES!!!
    Damn nasty scars on the poor piston....how the jug look?
    Get-r-fixed.
    Jan 2008
    TEXAS
    1,434
    the other side is identical...alot of groves...what do ya think. u think the exhaust port at it? would it be more to the center if that was the case> this is just on both sides...
    s.i.mafia
    Leaky pipe wont do that, jugs outa round proly. Piston slap back and forth IMO and proly caught the ext port or some shit.....How old was the piston and jug bore?
    Jan 2008
    TEXAS
    1,434
    jug will clean up with hone very light scratchs..that isnt rust....aluminum doesnt rust yo!!
    s.i.mafia
  9. #7
    Jan 2008
    TEXAS
    1,434
    about 50-60- hours...on fresh bore...
    s.i.mafia
  10. #8
    Thats why i was wondering, cause that shit looks like rust so i was like WTF willis....huck a new piston in and hone'er up and be done.
  11. #9
    Apr 2005
    West/Central,PA
    5,567
    if you can some good pics of the bore that be cool..or you already hone it?
    i would say the cylinder got hot and swelled causing the hotter ex. side to expand more and jack the piston...
    or like stated above the bore is outta round...the ones ive seen with and outta round bore usually break the skirts off though..that is an interesting wear mark...
    is this jug ported?
    PM for a quote
  12. #10
    Jan 2008
    TEXAS
    1,434
    ya ported, going in for some more work is y i pulled it. ports are good. i havent honed it yet, i am gonna do some work on the cylinder. i will take some more pics...looks like i got some contaminants in there...ya i am sure it got hot i ran the piss out of it at the dunes...or do u think it could be from not warming it up? if the cylider was outta round it would make certian spots wear faster but there are lots of fine scratchs in it..
    s.i.mafia
