Blaster liquid cooling kit
Page 1 of 6 123456 LastLast
Results 1 to 10 of 57
    Sep 2009
    New Jersey
    3,235
    Default Blaster liquid cooling kit
    Any of you guys ever hear about this just saw it on another forum.
    If so pros and cons
    Yamaha Blaster High Performance Liquid Cooling Kit
    2000 CR250R
    Pro Curcuit Pipe
    FMF Silencer
    ProTaper Bars
    1986 LT250R
    Being Rebuilt at current time
    Gussetted And Reinforced Frame
    Boyesen Reeds
    Barnett Clutch
    AAEN Top End Pipe
    38mm PWK Airstriker
    1997 Blaster
    66.75mm Wiseco Pro-Lite Piston
    Wildcard Agressive Trail/MX P&P
    Wildcard Head Mod
    Toomey B1 Exhaust
    Toomey 2-Stage Filter
    Boyesen Power Reeds
    WORKS Dual Rate Remote Ressie Fronts
    Nov 2007
    RENO_NOT*CAL
    1,794
    i think it has been talked about on here? i my self dont think that kit is worth a shit...
    Sep 2009
    New Jersey
    3,235
    ok cool figure I better ask here to find out the truth about this thing!!!!!!!!!!!
    2000 CR250R
    Pro Curcuit Pipe
    FMF Silencer
    ProTaper Bars
    1986 LT250R
    Boyesen Reeds
    Barnett Clutch
    AAEN Top End Pipe
    38mm PWK Airstriker
    1997 Blaster
    Wildcard Head Mod
    Toomey B1 Exhaust
    Boyesen Power Reeds
    May 2007
    SOMD
    7,770
    Well it basically only cools the head.
    Could be worth it if your into changing the compression ratio without having to get the head cut or buying a bunch of different heads.
    I guess it depends of the money your willing to spend.
    "Paul,
    Thanks for sending the pictures - looks like a lot of fun! You did a great job."
    Regards,
    Bob Hannah
    My motor is from 79'....Where will your 450 be in 30 years???
    DC facebook / Paul Baugher
    For details click here
    Sep 2009
    New Jersey
    3,235
    Ok thats what I thought its like a cool head for a air cooled motor.
    And so it seems it for the guy who has the unlimited budget.
    2000 CR250R
    Pro Curcuit Pipe
    FMF Silencer
    ProTaper Bars
    1986 LT250R
    Boyesen Reeds
    Barnett Clutch
    AAEN Top End Pipe
    38mm PWK Airstriker
    1997 Blaster
    Wildcard Head Mod
    Toomey B1 Exhaust
    Boyesen Power Reeds
    Nov 2009
    Chesapeake, Va
    130
    I'd like to know how it pumps water.
  9. #7
    Sep 2009
    New Jersey
    3,235
    good point 2001
    2000 CR250R
    Pro Curcuit Pipe
    FMF Silencer
    ProTaper Bars
    1986 LT250R
    Boyesen Reeds
    Barnett Clutch
    AAEN Top End Pipe
    38mm PWK Airstriker
    1997 Blaster
    Wildcard Head Mod
    Toomey B1 Exhaust
    Boyesen Power Reeds
  10. #8
    Nov 2009
    Chesapeake, Va
    130
    Yea, I see that big ass aluminum radiator under the front plastic. It ain't doing any good though, without water pumping through it. I think you'd be better off with the air cooled head.
  11. #9
    Jan 2007
    north east indiana
    654
    electric, its been talked about before just do a little search
    http://forums.everything2stroke.com/...d-blaster.html
    ANDY
    my 2000 blaster
    foam filter from toomey
    4 degree key from dustin420
    toomey b1
    oil block off kit
    Boysen power reeds
    worn out stock front tires
    20x11x8 razr
    bored .020 over
    3mm stroker
    have flotek port and polish to match stroke sometime
    Daddy always said a 4 stroke is about as useful as a shovel with a rope handle.
  12. #10
    Under the Instructions Page it talks about the water pump.
