my blaster is running backwards????
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Default my blaster is running backwards????
    Went to ride my blaster i put it in gear and let out the clutch it went backwards...what do i do??? i have searched it already but cant find anything...any advice
    Feb 2010
    shelbyville,mi
    2,661
    well a buddy of mine had this happen i dont remember what he did something was backwards tho..
    1996 banshee
    trail bike
    1989 banshee
    backup trail bike(build in progress)
    1989 banshee
    (about to start my drag/dune build again)
    Sep 2006
    New York
    3,179
    Check the stator and woodruff key.
    2001 Yamaha Banshee,Passion Racing XC 12 port 4 mil,milled head 110 octane, Paul Turner Mids, Pod Filters, ITP HD's F/R, Nology Coil/Hot Wires,V-force 3 reeds, boss intake,33mm pwk's.
    Check out these Fearnot Brand threads!
    Powerful Pictures, http://forums.everything2stroke.com/...ad.php?t=41165
    Worlds Best 250 Strokers, http://forums.everything2stroke.com/...ad.php?t=34607
    "My fellow Americans. As a young boy, I dreamed of being a baseball, but tonight I say, we must move forward, not backward, upward not forward, and always twirling, twirling, twirling towards freedom!"
    Oct 2008
    Anderson, Indiana
    2,840
    Yep......ignition can cause it. Check all the electricals.
    If it ain't broken yet, you ain't tryin' hard 'nuff.
    Sep 2008
    Auburn WA
    1,857
    I have seen one case where the motor kicked backed then fired and was running in reverse. The guy shut it off, kicked er again and all was good, 2 strokes don't care what direction they are running.
    Can't see him but there is a guy on a banshee under all that roost.
    Oct 2010
    SC
    1,696
    Blog Entries
    1
    I had this happen its the timing that's off or it was in my case
    If it doesn't smoke, it's broke!!!
    Support our site>> E2S Premium Membership
    FACEBOOK!
  9. #7
    Oct 2010
    SC
    1,696
    Blog Entries
    1
    and if you have an adjustable plate make sure its not loose that's what haPpen to me
    FACEBOOK!
  10. #8
    Feb 2010
    Delaware
    245
    Quote Originally Posted by Fearnot View Post
    I agree with that. If the key shears, it will put the timing way off.
  11. #9
    Dec 2009
    northern PA
    317
    its the woodruff key foe sho', can you do us a favor and get some vids of yourself bangin some gears backwards?
    FLOTEK ported Airsal BBK runnin on 110 octane
    FLOTEK modded head
    FLOTEK lightened flywheel
    +3 vitos crank
    +4 lonestar axle
    +???? timing
    barnett dirt digger clutch
    power pros head pipe
    custom ported RAD valve
    banshee fronts
    400ex rear shock
    full hydros
    blasterfreek case saver, chain slider and rollers
  12. #10
    Jan 2009
    64° 49' N / 147° 15' W
    3,139
    Quote Originally Posted by Super Noober View Post
    Hahaha! I've been asking that for years.... no ones done it yet!
    03' blaster
