YZ 125 compression questions, race fuel, pump fuel
Results 1 to 9 of 9
    Sep 2007
    Kansas
    2,612
    Default YZ 125 compression questions, race fuel, pump fuel
    Just rebuilt the top end on my 125 with a fresh piston and ring, and a cometic thin base gasket.
    What is the stock compression?
    What is the max compression that can be run with pump fuel?
    When do i have to run race fuel?
    What is too much compression for a 125?
    I havnt checked the compression yet but it seems pretty high and i just wanted to make sure im doin the right thing.
    Thanks
    Will
    I dont just want to be another guy, with a pipe and a payment...
    1986 Honda TRX 250r
    1998 Yamaha YZ 125
    1990 Suzuki RM 250
    1986 Kawasaki JS 300
    1986 Kawasaki JS 550
    well u can take the head off and check the gap off the rings and the wall u can call a dealer or a bike shop and get that becuse if it feels like that the might be to samll of a gap and not geting enuff oil throw and scoring ur walls wich wud make it feel like its got grat compreshon becuse ur just comperesing old air and ading new at the same time becuse the pip foris some old air back in to the cylinders so id check the gap and im not trying to be a dick if im exsplaning some thing to u that u might allredy know but thats the only way i know to exsplane it
    if it ant mud it ant fun
    Sep 2007
    Kansas
    2,612
    I have checked the ring end gap and checked the cylinder wall clearence and its all perfect within spec. Im running plenty of oil at 32:1. I just want to know if its going to detonate with pump fuel? I think my squish is about 1MM. and all my ports line up perfect at BDC so i dont think anything can be wrong there.
    1986 Honda TRX 250r
    1998 Yamaha YZ 125
    1990 Suzuki RM 250
    Sep 2007
    Kansas
    2,612
    SO i need help right away, leaving at 5 tomorro morning for the race, I checked my compression and its 185. I should be able to run just straight 91 and be fine correct? I need an answer ASAP!
    Thanks
    1986 Honda TRX 250r
    1998 Yamaha YZ 125
    1990 Suzuki RM 250
    yes, 91 will be fine, but i recommend finding a fuel that is non-oxyigenated...
    2006 Yamaha YZ250
    KYB SSS Suspension setup by Enzo Suspension
    Pro Circuit Exhaust
    RB Designs Head
    ASV F3 levers
    Tag Metals Triple clamp
    Pro Taper Bars
    IMS Pro Series Pegs
    Motion Pro Twist Throttle Assembly
    UFO Restyle Kit w/ Aktiv Graphics
    VF3 Reeds
    Dunlop Geomax MX 32 tires
    Sep 2007
    Kansas
    2,612
    I re checked the compression after complete break in. (one race) haha, and it reads 200 even now. Im sorry for so many questions, but this should be a 50-50 mix of race fuel and 91 correct?
    Thanks
    1986 Honda TRX 250r
    1998 Yamaha YZ 125
    1990 Suzuki RM 250
  9. #7
    Mar 2007
    Vacaville, California
    6,471
    I would run 50/50 in it. I run 50/50 in my CR and it's stock compression.
    E2S MODERATOR
    1988 Yamaha Blaster
  10. #8
    250 PSI and on pump gas here with no detonation.
    2006 Yamaha YZ250
    Pro Circuit Exhaust
    RB Designs Head
    ASV F3 levers
    Pro Taper Bars
    IMS Pro Series Pegs
    VF3 Reeds
  11. #9
    Sep 2007
    Kansas
    2,612
    Quote Originally Posted by MX86 View Post
    Stock squish, squish band, porting, bore and cylinder? How are you doing this?
    1986 Honda TRX 250r
    1998 Yamaha YZ 125
    1990 Suzuki RM 250
