For Sale Tons of LT500R Quadzilla parts on eBay -- selling my stash!
Results 1 to 8 of 8
    Jul 2010
    Genoa, OH
    1,251
    Default Tons of LT500R Quadzilla parts -- selling my stash!
    Go here for the first item, and then look at "seller's other auctions": http://www.ebay.com/itm/130764165728?ssPageName=STRK:MESELX:IT&_trksid=p39 84.m1555.l2649 Right now I've got 18 items listed with about another 30-40 more coming over the course of the next week. Ebay is running a "free listing" promo on eBay motors right now. On average, it's costing about only $0.50 per listing even with up to 12 pics and with BIN. otherwise, I would've listed everything here.
    I also have a couple big items that I prob won't eBay due to shipping: (SEE BELOW)
    Ask me what else I've got and I just may have it. I've got a 2nd crank, 3 more CDI's, a 2nd stator/flywheel, swing arms, reed cages, hubs, a-arms, front calipers, misc OEM parts still in baggies, used 88mm & 86.50mm piston/rings/gearing/washers/pin, kicker gears, rear brake set, used clutch assemblies, key switch, stock carb, twist throttle, 88+ intake boot, etc. Just haven't gotten around to pics & listing yet. And will have some more big stuff once I get some parts swapped off my "keeper" '88.
    I've also got a cherry 1988 LT500R Zilla for sale! Was asking $2450, but I'm moving and will take an even $2000 cash firm. Clean & mean. See other classified ad!!
    -Dan
    Last edited by DMoneyAllstar; 09-17-2012 at 02:18 PM. Reason: ADDED MORE PARTS! =)
    "'71 'Cuda, Plumb Crazy Purple, Guy wants $14-grand, WHAAAAAAT?, I give him sed-ney-fy-hundrit!" -Joe Dirt-
    do you have a phone number i can call
    Jul 2010
    Genoa, OH
    1,251
    Regarding parts or regarding my quad for sale? Sent you a PM earlier.
  5. #4
    Jul 2010
    Genoa, OH
    1,251
    Still tons of parts on eBay, plus I have some larger-sized stuff that I'll be listing here and on Craigslist. My house is officially sold and this stuff has to go - I don't want to move it!
    Here's my local ad: http://toledo.craigslist.org/rvs/3277622958.html
    These items are PICK-UP ONLY (unless noted):
    1. LT500R seat, one small tear, some corner wear - $50
    2. LT250R Ceet seat, no tears. (ON EBAY)
    3. LT500R complete rear end: $140 for whole thing assembled (ON EBAY)
    - Swing-arm, no cracks or welds, includes skid plate, all pivot bearings, bolt & nut: $80
    - Axle w/ rotor, sprocket, nuts, axle hubs, and wheel hubs: $50
    - Rear carrier with all hardware and rear adjust plate: $50
    4. LT500R front suspension, complete: (ON EBAY)
    - A-arms with GOOD ball joints/seals and mount bolts: $85
    - Shocks, good, for the pair: $45
    - Tie rods, good, with nuts: $20
    - Hubs, spindles w/ tie rod bracket, pair: $25
    5. LT500R HYBRID frame, 87-90 LT250R frame with all work done for LT500R engine. Front lower rear a-arm mounts cut to fit up the LT500R a-arms. Upper shock mount cut off to fit-up LT500R shocks. No pic (search my builds). $50
    6. LT500R frame, straight, has two square tube cross members between lower a-arm mounts for strength. No pic (search my builds). $50
    7. LT250R rear shock assembly with linkage, 87-90 models, good. (ON EBAY)
    8. LT500R rear grab bar. $15 (ON EBAY)
    9. LT250R rear grab bar: $10
    10. LT500R steering stem and straight bars with all hardware (my right big toe is NOT included, lol). $45 (ON EBAY)
    11. LT500R fuel tank w/ cap and good petcock. $25 PETCOCK SOLD
    12. LT250R fuel tank petcock. $10 + $5.35 shipping to lower 48 USA.
    13. LT500R rear FMF Powercore silencer, nice. (NO LONGER FOR SALE, GOES WITH ZILLA THAT'S FOR SALE)
    14. LT500R chrome FMF Fatty head-pipe with light surface rust in curves. (ON EBAY)
    15. LT500R FMF Gold Series head-pipe, silver ceramic exhaust paint, small dings. (ON EBAY)
    16. LT500R radiator set, complete. Rad, hoses, cap, top mount bolt, overflow w/ tubing. (ON EBAY)
    17. LT250R radiator set, complete. Rad, cap, top mount bolt. (ON EBAY)
    18. LT250R rubber mounts/grommets and good vented cap for fuel tank (no tank included). $1 + $5.35 shipping to lower 48 USA.
    19. LT500R rubber mounts/grommets and good vented cap for fuel tank (no tank included). $1 + $5.35 shipping to lower 48 USA.
    OR MAKE ME AN OFFER. ALL PARTS MUST GO. MOVING IN LESS THAN A MONTH!
    Parts ship out of Perrysburg, OH 43551. Small packages via USPS, and large ones via FedEx Home Delivery (if you use a business address, you can use FedEx Ground which is slightly cheaper). I prefer prefer prefer FedEx given a couple costly hiccups I've had with USPS. Did I mention that I prefer FedEx? ;)
    PM me if interested. =)
    -Dan
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	28282   Click image for larger version.
ID:	28283   Click image for larger version.
ID:	28284   Click image for larger version.
ID:	28285   Click image for larger version.
ID:	28287   Click image for larger version.
ID:	28288   Click image for larger version.
  6. #5
    Jul 2010
    Genoa, OH
    1,251
    And here are more pics of the parts....
ID:	28291   Click image for larger version.
ID:	28290   Click image for larger version.
ID:	28292   Click image for larger version.
ID:	28293   Click image for larger version.
ID:	28295   Click image for larger version.
ID:	28296   Click image for larger version.
  7. #6
    Jul 2010
    Genoa, OH
    1,251
    And here are the head pipes...
ID:	28300   Click image for larger version.
ID:	28299   Click image for larger version.
ID:	28298   Click image for larger version.
  8. #7
    Do you still have a crank for sale? Thanks
  9. #8
    Jul 2010
    Genoa, OH
    1,251
    Nope, never had a crank -- just a roller. It's all sold and gone. Couple auctions left on ebay for this and that.
