Results 1 to 9 of 9
Thread: head gasket?
    Sep 2005
    northeast PA
    52
    Default head gasket?
    when i put a new head gasket in, does it go in dry or is there some sort of sealer that i need to put on it? my quadracer is slightly bored over at .010 but no one makes a head gaskets for bored over quadracers that i can find, will a standard size gasket work since my quad is only bored over a little bit?
  2. #2
    Jan 2006
    Nevada
    1,230
    just put a lil grease on each side
    2005 YZ250 - FMF Gold Series Fatty Pipe, Titanium 2 Silencer, UNI Filter
    2006 YZ450F - White Bros Full Carbon Exhuast, UNI FIlter
    92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
  3. #3
    May 2004
    NW Indiana
    2,794
    the standard size gasket should be fine. I put them on dry, ive never heard of anyone putting grease on them
    89 LT250R
    Ported
    Head Re-domed
    V-Force2 reeds
    39mm PWK
    PSI pipe
  4. #4
    Jan 2006
    Nevada
    1,230
    light greasing helps make a good seal..cheaper than gasket sealer but does the same purpose
  5. #5
    Mar 2005
    ohio
    494
    I never put sealant on head gaskets and have never had own leak or blow out. Standard size will work fine.
  6. #6
    Feb 2006
    MI
    1,453
    Why not use Permatex Copper spray gasket?
  7. #7
    Jan 2006
    Nevada
    1,230
    some engines need a gasket that raises the head a certain higth
  8. #8
    Feb 2006
    MI
    1,453
    And a 10 thou overbore wouldn't need a bored gasket.
  9. #9
    the head gaskets are made to stick or melt to the head and cylinder when the engine gets up to operating temp. after the temp has been up to operating temp the head gasket will attach melt to each surface, that way it seal better.
